It is currently Fri Aug 15, 2025 11:03 am
 Post subject: 90 Degree Pencil Grinder
PostPosted: Tue Oct 28, 2014 9:29 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Anyone use one and have a recommendation?
PostPosted: Tue Oct 28, 2014 9:45 am
Last Name: Russell
State: Michigan USA
Never heard of one.
But here is one just in time for Halloween... laughing6-hehe
PostPosted: Tue Oct 28, 2014 11:24 am
Last Name: O'Melia
City: Huntsville
State: Alabama
This is what I mean. These are pricey. Just wondered if there were alternative makes at lower prices.
EDIT: Nevermind. Seems I was looking at the pricing incorrectly. These are typically in the $129 range. Meaning I am getting one. :)
PostPosted: Wed Oct 29, 2014 7:01 am
Thanks for the picture. I sure couldn't figure out why someone would want a pencil with that wide a bevel angle.
Mike Lindstrom
PostPosted: Wed Oct 29, 2014 7:34 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Some people call them pneumatic routers. They call them pencil grinders because of their shape and size and the way you hold them. I have the normal grinder. It's awesome. But I want this for brace shaping.
PostPosted: Wed Oct 29, 2014 8:23 am
they are actually Pencil Die Grinders and are often used in Tool and Die repair. I have used them but for luthiery the straight one is more useful.
PostPosted: Wed Oct 29, 2014 11:18 am
yep it's a die grinder. handier with a sanding disc on the end of it.
PostPosted: Wed Oct 29, 2014 12:05 pm
Last Name: Russell
State: Michigan USA
LOL... I have never heard of them being called a pencil grinder. I do know what a die grinder is and actually have one but I don't use it on guitars because it is air powered and it tends to spit oil out once in a while.
All I could think of was you meant a pencil sharpener but never heard of a 90 degree one... hence the Halloween one... laughing6-hehe
Bob
PostPosted: Thu Oct 30, 2014 8:51 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I agree. But for my desired application, 90 deg is the way to go.
PostPosted: Thu Oct 30, 2014 8:58 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Bob
You don't know what your missing. These things are awesome for detail work. The exhaust port is rearward. A plastic flex hose extends that a foot or more away from the tool. Shouldn't be spitting oil anywhere near your work
(you can order these from John Hall, Blues Creek Guitars)
http://www.amazon.com/Sioux-Pencil-Grin ... il+grinder
PostPosted: Sat Nov 01, 2014 9:19 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
My Sioux 90 Pencil Grinder arrived yesterday. I used a 1/8" tungsten carbide Dremel drum bit and 80 grit drum sanding bit to shape top braces on 5 tops today. Worked like a dream.
PostPosted: Sat Nov 01, 2014 9:33 pm
Last Name: Russell
State: Michigan USA
Thanks for the info and the link Mike, There have been times I have wanted something more than my Dremel and that looks like the tool. I have used my Die grinder on tools and jigs and I know it is really handy so I may have to look into buying one of these. I can see where the 90 degree head could be pretty useful too.
Where did you find that 90 degree one?
Cheers,
Bob
PostPosted: Sun Nov 02, 2014 3:42 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I like them a lot... the straight one that is, have not tried the 90 degree ones. They're very easy to control which allows for great precision.
The only problem is they require a lot more air than it looks. Unless you got a 10HP rotary screw compressor, it's going to be running nearly all the time. It's actually pretty bad energy efficiency too, electrics would be far more efficient in terms of amount of equipment needed, except a lot of them tend to suck (Dremel for example) It's like requiring 5HP of power draw for a tiny tool that can't carve 1/8" worth of materials... even Foredom type tools can do better, and those are like 1/8HP.
Typhoon Guitars
PostPosted: Thu Nov 06, 2014 4:34 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I got mine here: http://www.browntool.com/Default.aspx?t ... 33&Level=a
I do not have a 10 HP rotary screw compressor, nor do I need one. I do not even have a 5 HP compressor. But I do have a 60 gallon tank. And yes, they use a lot of air (more than you would think). The problem I have noted (so far) is that electric grinders have trouble making the 90 degree turn in a small space. Dremel makes such a transmission, but its bigger than the Sioux 90 degree. If I am not mistaken, in the Sioux, the turbine is right there at the collet. I guess it all depends on what your application is. Mine required a small head. It's also nice not having the device heat up in your hands, or transmit nasty vibrations.
If you have a straight pencil grinder that does all you need, I would not bother with this.
Users browsing this forum: ThomLuth and 18 guests
